PowerFlex 755 with Safe Speed (w/ DUAL ENC)
phuz
Jun 2008
Mohnton, PA
1,044
I'm having a bit of trouble startup up this PowerFlex 755 with Safe Speed module. I have a dual-encoder module wired up and a safe speed module configured for dual speed check (parameter 27). Safety mode (parameter 21) is currently set to disable. Dual encoder module has the safety jumper in the enable position. When I "jog" the drive from the control bar within connected components, it jogs at 10hz despite my setting. If I hit start, it says "at reference" but stays at 0hz despite my setting. Clearly I am forgetting some parameter(s).
Edit: turns out the customer installed a secondary ethernet module (port 5) and that's where the cable was. I changed the reference port and it's working.
However, when I set 15hz on the control bar, it only ramps up to about 11.8hz
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
273
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
172
So I'm replacing a terminal block on the inverter board for a 755. I'm wondering if anyone knows what conformal coating would be best? I'm not...
138
Powerflex 755, running 2 weeks, and faulting with code 17 input phase loss.
228
Hi All, This is my first PowerFlex 755 drive setup and I am having an issue with when I start the drive it runs at my minimum speed 5Hz, but...
432
