Powerflex40 Over Prosoft/Compactlogix Profibus
GTUnit
Oct 2009
Orange, CA
401
Can someone Please help me figure out how to write drive parameters over Profibus. Help Help
Controller: Compactlogix L43
Profibus Master: Prosoft MVI69-PDPMV1 in chassis profibus card
Drives: Powerflex 40 with 22-COMM-P cards
Network is up and drives are visible/controllable
I'm a little bit confused. If you are using Rockwell drives and PLC's, why are you using Profibus, instead of something supported natively on both devices?
In a Siemens system, there are prebuilt blocks to send parameters over a profibus or profinet network. I don't know how you would do it from a logix.
Our company has a history with Siemens so there are some left over "standards" for our custom equipment. Drives are on profi as well to keep everything on the same network. Did not say I like it, its just what I have to work with.
Hi Guys! First of all let me tell you that I am not a programmer or anything close to it. I know the little things I know because of PLCtalk...
2,661
All power flex inverters are suffering from F71 fault randomly across the Device net network which cause Operation to stop. As a resolution from...
3,223
Anyone know where I can find the wiring diagram AB supply with a wired MCC cubicle containing a PF40 drive? I want to duplicate the Hand-Off-Auto...
1,594
I am designing a system which utilizes several different pumps. I have always used powerflex 4 and 40's for smaller motors in the past and...
1,519
Hello Gentelmans, I try to establish connnection with PowerFlex 40 using Usb-RS485 converter like this...
2,684
