Powerflex700 Flying Start
hhuong
Nov 2004
58
Hello All,
I am in need of help for the problem that I had with Powerflex700 Drive. Here is the situation
First, I enabled the flying start (P169=1). I start the VFD and it ramp up to the commanded frequency. When i send a stop command, the VFD will stop. Again, if i re-send the start command while motor coasting down, the VFD couldn't ramp from the current motor rotation and instead it ramp from 0 rpm, which give me high current motor overload alarm.
Drive Information: 20BD077-A3ANNANA0
Motor: 30HP
sw version: 3.002
Does anyone experience this before? Any suggestion is deeply appreciated. Thanks
BR,
herbert
Hi friends. I am working on PF700, and drive is showing at speed no faults but when I am hooking up the motor, motor doesnt starts and only shows...
1,729
I want to connect my PLC 5/40 to my Powerflex 700 trough RIO remote I/O. I am connected to the PLC trough a 1. How is the wiring in the Remote...
1,277
We have a Power Flex 700 VFD installed which in turn gives power supply to 55 kw motor. Once the VFD tripped due to over heating of vfd. We...
10,121
Hello, I used the powerflex 700 driver,the driver via 20-comm-e with PLC (1769-L32E) communication,I use the rslogix5000 software config the...
2,967
Please help/advice, On Powerflex 700VC with DeviceNet communication card, the drive is off by 15 rpm at 500 RPM, at 100 RPM the actual speed is...
1,263
