PowerFlex700 remove DeviceNet
Narlin
Mar 2010
phoenix
320
[FONT=&quot]Hi,[/FONT]
[FONT=&quot]I have a previously used PowerFlex 700 with DeviceNet and I want to use it to run a 20HP motor powering a water line at constant pressure. This was recovered from some surplus equipment and it was working when removed from service. [/FONT]
[FONT=&quot]I don’t have a DeviceNet network and don’t intend to get one. Can I uninstall the DeviceNet module and use the standard control option 32 pin I/O? If so, what advice might I get with respect to returning the machine to a factory default condition.[/FONT]
[FONT=&quot] The Frame 2 has a 20-COMM-D FRN V1.004 installed. [/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]narlin[/FONT]
I might be mis-speaking, but I believe you can use it as is. You can use a HIM Module to reset it to defaults. The 20-COMM card can be removed or stay there - it's just another port that can be used or ignored.
If you have a safe-off card, the drive will need it to be wired up properly or removed and jumpers re-installed.
I am sure that i don't know what a safe off card is? Can you describe that a little better.
If the HIM turns out to have password protection, can i just purchase a new HIM? Is the psw in the HIM only?
Hi friends. I am working on PF700, and drive is showing at speed no faults but when I am hooking up the motor, motor doesnt starts and only shows...
1,732
I want to connect my PLC 5/40 to my Powerflex 700 trough RIO remote I/O. I am connected to the PLC trough a 1. How is the wiring in the Remote...
1,279
We have a Power Flex 700 VFD installed which in turn gives power supply to 55 kw motor. Once the VFD tripped due to over heating of vfd. We...
10,123
Hello, I used the powerflex 700 driver,the driver via 20-comm-e with PLC (1769-L32E) communication,I use the rslogix5000 software config the...
2,969
Please help/advice, On Powerflex 700VC with DeviceNet communication card, the drive is off by 15 rpm at 500 RPM, at 100 RPM the actual speed is...
1,266
