pre-tunning error in pid compact
jayleela
Aug 2015
BHUJ
Hi
I am using S7 1200 PLC . I want to use pid compact to control pressure trough manupulating the speed of motor using ACS850 vfd. The pressure sensor input range is -10 to 5mbar as a 4-20mA
receive pressure value nearest 0 to -3mbar,so i use setpoint is -1.16mbar,
i have tried pretunning but i obtain the error process value is close to setpoint,
For successive pretunning formula,
sp-pv >0.3 (high pv-low pv)
according to this formula pretuning is not possible,
if possible then anyboady help us
Hello all! New user as of a day ago, first post! Just wondering if anyone has ever purchased and / or knows where to purchase a pre-built PLC...
2,874
I am working with a customer template who uses pre and post instructions in Graph. I have not used these before in Graph, and I am trying to...
1,393
Hi Guys, What the quick and dirty way to load a PRE value to a counter in a ML1200 from a C-More HMI? Having trouble using the HMI to reset a...
1,341
I am trying to figure out how to use the predefined AOI, cant seem to find it in the manual for the add on instructions. Any help out there on a...
1,745
Hey guys- I have an array of 30 timers. I want to copy a # into all 30 of the .PRE registers. Can I use a copy instruction into Timer[0].Pre with...
24
15,853
