Pressure rate control PID loop
I've got something similar that we built at the shop but it's a hydraulic flow test stand. I used www.measurementcomputing.com hardware and the sample rate is EXTREMELY fast and user configurable, they are also quite inexpensive and have USB connectors for interfacing with a PC.
I'm trying to work through a question I have about using a PLC, plus separate temperature and pressure controllers on a plastic extruder rebuild...
2,987
How to calculate flow Rate of water and Steam ton per hour with pressure differential.
32,143
I just realized that the three new horizontal tanks tanks we're installing this weekend will need a CPT and some in order to allow the provided...
4,205
I had posted an earlier thread about a scale w/parameters issue. Turns out it may not be the issue. Since, I do not have much PLC experience, nor...
23
7,060
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
269
