Pressure Switch recommendations
Mar 2016
Raleigh
88
I am looking for a pressure switch with the range of up to 100 psi. Single throw, dual pole. This will be a pneumatic application. 1/2 NPT would be great.
I would really like an integrated pressure gauge.
I have had really poor luck with anything labelled Ashcroft.
Any suggestions would be appreciated.
Wika has a solid state switch (PNP or NPN) with a digital display, but it requires DC power. Some particular function is not configurable via keypad, but I forgot which. There is some setup software but I'm not familiar with it.
Spec sheet here:
http://www.wika.us/upload/DS_PE_PSD_30_en_us_17661.pdf
manual here:
http://www.wika.us/upload/OI_PSD_3x_en_de_fr_es_13551.pdf
United Electric has conventional blind electro mechanical pressure switches, like the H100, with no visual indication. You could pipe a pressure gauge to it on a Tee.
http://www.lesman.com/acatalog/UE_H100.html
Square D is an industry standard for plain jane run of the mill pressure switches. Air compressors, well pumps, I see them everywhere. I would not hesitate to install a T and hang a gauge off one side and the pressure switch off the other.
I think we order ours from Grainger usually.
Company wants a digital pressure switch panel mounted in a 8x8x6 enclosure on a machine, near where the operator stands for ease of adjustment...
1,189
Hi All, I was asked to see if I can get air pressure readings from lid weld station to an HMI ? I am not sure if this is even possible. Not sure...
3,969
i am a beginner plc programmer and have some confusion, a little help would be appreciated . why do we use a normally close contact when we are...
3,113
Hi my friends. I have a problem with this pressure switch with analog output. I have it connected to the Balluff I/O link analog module (BNI...
1,845
Dear, I have a case where a centrifugal pump is sucking from a double compartment tank, usually for the dry run protection of the pump, we use...
7,685
