Hi, I'm trying to send PDF screenshots from my 1500 comfort panel HMI to a specific folder in an IPC that is connected on the same network. It is currently setup so that the PDF screenshots are saved on a USB drive connected directly to the HMI. I use the "print screen" button to send the screenshot to the USB drive.
I'm using the PDF V1.5 driver to save screenshots to the USB drive but it doesn't give me an option to change the directory in the HMI printer settings. Saving to the USB drive works but it's locked to USB port 1.
Is there a different driver I should be using that will allow me to send the screenshots to my IPC, or any other computer with Windows 7? I'm also a little uncertain how I would map the folder in the HMI printer settings.
In the end I would like to have the PDF screenshots saved on BOTH the IPC and USB drive, but getting at least get the screenshots saved on the IPC would be great.
Thank you for any advice!
