Printing RSLOGIX Micro developer and PDF Creator
John Morris
Sep 2015
San Antonio
690
Hello all
Throwing out another trival question, Using RSLogix micro Developer.
I am trying to print out a l program using PDF Creator.
Now the program has four ladders to it, when I create the PDF, it will only print the main program, and none of the sub folders.
I have tried opening all of them together, one at a time, one highlighted, all high lighted, From the program files, But in each instance it will only create the main program.
I get 46 line of code, and the whole program has 489 lines.
Have I over looked something simple.................again?
Please advise, and thank you for your time in advance.
I don't use the Micro version or PDF Creator, but I do use the standard version and cutepdf printer driver.
If things are the same, and I suspect that they are, look in RSLogix under the file menu > Report Options.
It is there that you get to pick and choose what gets printed when you print a report in RSLogix. You may have a project saved in which those options have been set up to only include LAD2.
I had a student fooling around with settings tonight, and now when I try to print a program ladder, each rung prints on a separate sheet. Too many...
360
Hi. Today a coworker asked me to print a ladder from RSLogix 5 and it wouldn't work.:huh: It's not a matter of not knowing how, I used to be...
2,048
174
My company built a small test machine using a Micro800 PLC and CCW software. We chose the Micro800 because the machine is very simple. We are...
148
Looking to Print over ethernet with a 5069-L320ERMS3 Compact GuardLogix 5380 Safety Controller. Printer model yet to be provided. But a few...
1,609
