Pro/Con using PLC for analog input?
johnnie
May 2003
Flowery Branch, GA
My company does not use our S7 300 series PLC for analog inputs.
Instead we use these:
Tesar
Staiger
I ask the engineers why not let the PLC do the work??
They say too much programming....
What are the benefits of using these instead of the PLC?
Thanks!!
Maybe they already figured out what was meant by following :D
- rivers to 20mA ( current )
- Pt100-Fuehlern ( sensors )
- built in the 19"-Gehaeuse ( rack )
Ok, it could be that analog PLC card doesn't match the reqd. specs.
These seam to run much faster and have 16-bit reseolution. :confused:
PLC's for Process Control
We use PLC's for process control all of the time. I have one plant that has over 125 PID loops running in a single processor. Maybe your engineers haven't stepped up to the new millenium?
I justs realized that you said S7-300... That's a different issue. For one thing the 300 processor wouldn't be able to handle 125 PID loops. It does ok with 10 or so. That's the most that I've implemented in the S7 so that's all that I can speak to. FB41 is the block that we use for PID control in the S7. It's a peach. Not. You have to add code for bumpless transfer and cascade can be "interesting" to implement. Personally I think that they should give this block to their users but they don't. You have to pay for it. Typical Siemens (still love their PLC's though).
I've been trying to find the time to write my own FB but work has been a little busy of late.
Hey all, I'm new to the world of Schneider/Modicon, need some help..... I have inherited a Modicon M340 as part of some used equipment that our...
7,522
17,714
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
417
Hi guys, Do anyone have some experience with swapping out your old HMI for a Industrial Panel PC? If so, what can you tell me? - Right now i...
3,742
Hi, I'm converting a modicon program to allen bradley. I'm hoping someone that knows modicon can help me to understand what is happening on this...
1,552
