Modicon Pro Worx Plus - Floating Point Conversion Help
antsrealm
Dec 2010
Brisbane
207
I'm converting a modicon program to allen bradley. I'm hoping someone that knows modicon can help me to understand what is happening on this rung.
It seems to convert an Interger to FP then multiply two FP values and convert back to an Interger. I have the register values and am trying to reverse engineer the calculation. Problem is I get a bit lost when it goes to the FP value. I am trying to interpret how the FP value represents the integer? How does the result come about and how can I replicate this in AB.
See attached picture. I have included the values in a excel screenshot with the code. Thanks.
Ahhh Now I see the resulting FP value in the RegEdit View. This is how it should be and seems ok. I think i'm ok now.
If anyone can confirm that would be great.
Thanks,
Hi, I'm translating some old modicon code. First time I've worked with modicon in any deep capacity. Just want to clarify the output operation...
3,879
Hi I have a modicon 984 and HAD a pc issue with the dev PC that had the Proworx 32 software and programming on it. The hard drive took a dive and...
5,719
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hello all, My company have sourced a Modicon M340 PLC with a Magelis (XPT GTO4310) HMI. The intention here is to use this setup in order to...
3,702
Greetings, I'm using Unity Pro v8 (131118) with Modicon M340. I cut my teeth on PLCs with Modicon back in the early 90s but this is my first...
2,653
