Unity Pro, Modicon M340 Trending Issues
BAJ
Jan 2006
Maple Grove, MN
201
Greetings,
I'm using Unity Pro v8 (131118) with Modicon M340. I cut my teeth on PLCs with Modicon back in the early 90s but this is my first Unity project.
I'm having two issues I am hoping someone can help with.
1). I created a trend Friday and run it, but after a short while I got an error message
"Low Disk Space! Recording Stopped."
I have 5gb free on my C:\ and 50gb free on my data drive, so that's not it.
2). Now today I when I run a trend ("record"), the curves don't show up on the graph, it's just a blank graph. I still get the "Low Disk Space! Recording Stopped." message a short time later, so it would seem it's doing something but not showing the results.
Anyone have any suggestions? I tried re-creating the trend from scratch, same results. I rebooted also, same results.
Thanks,
-Brad
System with Microsoft Windows 7 Professional 32/64bits
System: Pentium Processor 2.4 GHz or higher, recommended 3.0 GHz
RAM memory: 2GB minimum; recommended: 3GB
RAM memory (using DTM or X80 drops) : 2GB; recommended: 4GB
Hard disk: minimum available free space 8 GB, recommended 20 GB
Microsoft Internet Explorer 5.5 or higher
On Windows 7 64bits System, installation of Windows 7 Service Pack 1 (SP1) is mandatory in order to use Unity Pro V8.1
Windows 7 Professional 64bits , with a minimum 4GB RAM memory is recommended for projects using more than 20 DTMs.
System with Microsoft Windows 8.1
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hello all, My company have sourced a Modicon M340 PLC with a Magelis (XPT GTO4310) HMI. The intention here is to use this setup in order to...
3,702
I was wondering if anyone knows if I can use the Unity Pro software to download an backup the logic from an older Modicon Micro CPU612?
1,637
Hi I have a modicon 984 and HAD a pc issue with the dev PC that had the Proworx 32 software and programming on it. The hard drive took a dive and...
5,719
Is it possible to add another column to the top of the ladder programming sections? I have eleven default columns now and can not change this...
1,955
