Problem download program to RSLogix Emulate 5000
jara
Jul 2010
Cordoba
100
Hi
I´m having some trouble when I try to download program to RSlogix Emulate, the fault is the following,
may be the problem is that I am running RSLogix emulate V20.01 and RSLogix 5000 V20.0
When I was runing RSLogix 5000 v.16 with emulate v.16 no problem.
The help file
Code:
Failed to go online with the controller
You  requested to go online with a controller of a type that is no longer  supported. You can only go online with supported controller types.
You might try switching the keyswitch on the Emulator from Run mode to Program Mode, and see if you can see it then.
Thanks for your recomendation, but I try and don´t work.
Do you know if is possible to run RSLogix Emulate 20.1 with RSLogix 5000 v.20?
It may be giving error because emulator minor revision is higher than rs5000 revision.
I tried mine lowering the revision from 19 to 18 in emulator. And it does the same.
19.11(logix) to 19.01(emulator) works good
Turns out I was having a different problem, but I followed this example to help:
http://www.plcdev.com/a_quick_tutorial_on_rslogix_emulator_5000
Example config didn't work, I used the following:
Assembly Instance Size
Input 1 2
Output 2 2
Configuration 16 0
I had previously configured my project for Compact Logix I/O (what my actual project hardware was) but you need to remove that and build I/O per the simulator.
Ryan
Dear Friends; We have OMRON CJ1M CPU23 with I/O cards at one of our machine. We have arranged a spare PLC and tried to download the program...
6,929
Scratching my head here. I'm trying to download an application to a PanelView 550 screen. Cat # 2711-T5A10L1 Ser A Rev F FW: V04.41 (just upgraded...
3,987
Hello everybody! At the beginning I downloaded a new procedure to the PLC 90-30 and it was ok, after that When I try to download other...
5,866
Dear Messes, I had a stupid question about downloading program to the PLC5/25 and every time I tried to download program to EPROM, it keeps on...
2,357
hi everyone, i accidentally changed COM1 paramater in my ZG3 series xinji plc now PLC is not connecting with PC please help,any ideas on factory...
2,408
