Problem in adding ENBT EtherNet Module in RSLogix5000
Apr 2014
Vadodara
49
Hello All,
Thanks in advance...
Friends today I am adding a New EthereNet Module ENBT through RSLogix 5000 software..but after adding details when I am clicking on OK, a following message is apperaing..
" Failed to create new module.
Failed to load a module DLL."
So, please guide me, what to do now ?
Whether my software is creating problem or something else is going wrong ?
Hello All,
PLCs don't have DLL's, so this sounds like an RSLogix 5000//RSLogixStudio 5000 install problem.
I agree that it's probably an installations related problem with RSLogix 5000.
To troubleshoot it, you will need to know the versions you are running, and the OS you are installing on.
The first question I would ask is if this is a new installation of RSLogix or if the software was already working properly and has recently malfunctioned ?
@ Ken Roach
We were using this software from last 4-5 months, not a new installation but this was the first time I am trying the addition of module through my software.
Hello I have a two controllers 1756-L61 and I would like to add an Ethernet Card module of one controller to the other one. When I search for...
884
I'm trying to add some Kinetix 6500s to an EN2T and when I create a new axis from the drive properties window, I get this prompt: "The axis...
4,945
Hi, There is a compare block being used 1100 times to compare variables to a constant value -999. The problem is that the GE is changing the -999...
1,860
Hi all, I just added an ACN to my network which already has 10 ACNs. After adding ACN with 2 Inputs and 2 Outputs, I opened RS networx and the...
3,209
I have a control logix network with a Logix5555 controller along with eight CNB modules at remote locations. Each remote location has various AI...
4,429
