Problem in Downloading Rockwell Firmware Updates
ashishm.gupta
May 2013
Gujarat
I am facing some problem in downloading the firmware updates from rockwell website. I have FT View ME Version 5.00.00 and I want to upgrade to Version 6.10 but after filing the details of serial no. and comapany name it is saying that the product is out of support[110].
Does any one can help?
Verify with your local RA/Allen-Bradley distributor about the status of your TechConnect contract (if any!).
You will not be able to download any software updates unless you are the owner of a valid support contract.
In addition, be aware that PanelView Plus terminal family had a major hardware change when they went to the 'PanelView Plus 6' logic module.
Older hardware PanelView Plus terminals (v3.0 through v5.10) cannot be firmware upgraded to run version 6.0 or higher firmware.
Newer hardware PanelView Plus 6 terminals (v6.0 and higher) cannot be firmware downgraded to run version 5.10 or older firmware.
Support eligibility is determined at the time you contact Rockwell Automation. If they have made an error and you really are eligible to download updates, they can fix your credentials easily.
Hello everybody, I have a problem with TwinCAT 3. When I try to activate a configuration and start IPC in Run mode I receive an error AdsWarning...
5,671
Dear Friends Please I face problem with Simatic PLC S7-415H , I can go online throw IP/TCP network and uploading the logic from PLC too PC but...
1,788
Hi guys!! Back again with another issue... Im currently working with Crimson 3 and a G315 HMI. While working on a database I previously...
2,461
Hi All! I added a combination I/O module 1794 IE4 XOE2/B to the end of 1794 RIO devicenet node. In RSNetworx for Devicenet V11 (CPR9) for some...
5,166
I have a Q00 PLC from a customer who want to modify some in Main program. First I upload program from PLC using GXWork 2. Everything is ok. But...
4,437
