Problem Installing on my New Laptop
jyg101
Nov 2007
NY
Hello I have a new laptop with of course no floppy drive I wanted to remove the activation from my old pc through the floppy drive onto the master floppy disk.
Now for my problem I installed RSlogix on my new laptop but I have no way of loading the activation onto my new pc with no floppy drive.Please can somone tell me how if there is a way or if I can use a usb thumb drive for the activation I tried to copy the master disk onto my thumb drive but still no luck.
Your best solution may be to source a USB floppy drive. That is what I use, it came with my DELL D620.
Or as a possiblity map a network floppy drive as your DRIVE A: from My Network Places-> Tools-> Map Network Drive
You should also be able to map a network drive and move it from there. For example, if you have a floppy on desktop and want to get the key to laptop.
1. Create writeable share, keystore, on desktop.
2. Map keystore locally on desktop as z: (if the share isn't on the root path of a drive)
3. On desktop, move the key from a: to z:
4. On laptop, map \\desktop\keystore to z:
5. On laptop, move key from z: to c: (wherever)
This isn't as involved as it may seem. It's also for "classic" with the EVMove utility. I'm not familar with how FactoryTalk keys work.
Hi everyone i'm trynna install Tia portal v15 The installation starts normale but it suddenly stops asking for a reboot , When i restart the...
32
8,285
Hello I am trying to install starter software on my simatic PG but the installation does not start with error that simotion scout is not installed...
2,702
Hi everyone! I have problem installing my new version of RSNetworx V21. During the installation, I have a message : ''Unable to continue...
1,702
Hello, Today I install Siemens PLC software SIMATIC Step7 v5.4. after installed, I start SIMATIC manager. it pop up "Run-time error 35600, index...
10,185
I have problem while I am installing FactoryTalk View SE V6.10 This Problem is password of installing Microsoft SQL Server Express 2008 as...
34,940
