Problem opening a .ap11 file
Holmux
Oct 2013
Aalborg
279
My first work using Siemens TIA portal and I have a problem that I hope I can get some help with :)
I need to make a few changes in a program at a costumer, the program runs in a ET200S CPU and is made with TIA portal v11, so far so good.
I made a fresh TIA portal v11 installation with WinCC comfort and updated the installation with update 2.
When I try to open the program file i get a message that I need to install WinCC Basic or comfort v11 update 2, I am going a little bit in circles with this installation.
Can I choose to go all in and get the latest TIA portal, with all the bells and whistles and upgrade the program to a newer version ? or am I stuck with version 11?
/Holm
Does it say "V11 Update 2" or is it "V11 SP2" ?
There is a huge difference
If you go all in and update to V15, you'll probably have to reset the CPU, before you can download the new project
/Holm
V13 SP1 will open V11 but nothing newer will. For example if you decide to go with or V14 or V15 you would have to upgrade your project to V13 SP1 first then upgrade that to the newer version.
It got pretty late last night, but I also learned the trick with version 14 and 15 won't open a version 11.
So for the future it might be a good idea to have a version 13 sp1 installed anyway, in case you run into older stuff.
I did some investigating into the installation and it seems like i am having some problems getting the version 11 to install correctly, I will try my older laptop win 7 or my XP laptop.
I have a V10.5 and I use a win xp laptop for this. I never had the a win 11 but it should run on both xp and win 7. I run v14 now on win 7 and it works perfectly.
HI.. I am facing this problem while opening the software. please help
1,166
This problem has been started since the migration of a v9 application to v10. It's a known issue with Rockwell, and their solutions are not...
941
Hi, everyone!. I'm having a trouble opening the HMI projects in Factory Talk View Studio 5000 v9.0. Yesterday they opened perfectly, but today...
1,668
Problem in opening RSlogix5000 software. the grace period is over error occured. how solve these problem please help
2,441
Hi Guys,:banghead: I have a problem opening an old project file in RSLogix 5000 V10.06. I have RSLogix 10-16 installed and the project file opens...
5,900
