Problem Opening RSLogix 5000 v10.06 project.
JanHoltz
Oct 2010
South Africa
Hi Guys,o_O
I have a problem opening an old project file in RSLogix 5000 V10.06. I have RSLogix 10-16 installed and the project file opens fine on the PC running the line.
I am, however, trying to open it on my laptop running windows 8.1. All other project files, ranging from v10-16 open fine except this one. The error message I am getting is as follows:
RSLogix 5000 Fatal Error
Fatal Error!
Application Path: c:\Program Files\Rockwell Software\RSLogix 5000\ENU\v10\Bin\RS5000.Exe
Version: V10.06.00
Source File: RxServices.cpp
Line Number: 246
Error 0xc0000005 (-1073741819)
0xc0000005 - No message available for error.
Press OK to terminate this application.
Any help would be appreciated, I don't want work on the production line if I don't have to.
Thank You.
That error code is very similar to the one described in RA Knowledgebase article 41061 (TechConnect Required).
The workaround suggested in that Knowledgebase article is to hold down the control and shifts key while directly launching a higher-than-v10 version, then going back and doing the same thing to launch v10. Holding down Control and Shift causes the "recent launch" variables to be cleared in Windows.
The direct executables are each located in their own folders, like:
C:\Program Files\Rockwell Software\RSLogix 5000\ENU\v10\Bin\RS5000.exe
RSLogix 5000 version 10 predates Windows 8.1 by about thirteen years, so I'm not surprised they don't work well together. Windows XP virtual machines are hugely valuable when running old software, and in my opinion VMWare Workstation is the best value for software I've ever bought.
I'm not sure about Windows 8 compatibility, but V13 is the oldest version of RSLogix 5000 that can be installed in Windows 7. So, you'll need an old XP PC or VM as Ken suggested to install V10 on.
Thanks for the reply but this did not work :(.
I think you guys are correct, my laptop that kicked the bucket, was running XP. And the one I am running now is windows 8.1. So I think I am going to have to install a virtal machine and try that. Thanks again for all the replies and advice.
HI.. I am facing this problem while opening the software. please help
1,166
This problem has been started since the migration of a v9 application to v10. It's a known issue with Rockwell, and their solutions are not...
941
My first work using Siemens TIA portal and I have a problem that I hope I can get some help with :) I need to make a few changes in a program at...
3,820
Hi, everyone!. I'm having a trouble opening the HMI projects in Factory Talk View Studio 5000 v9.0. Yesterday they opened perfectly, but today...
1,668
Problem in opening RSlogix5000 software. the grace period is over error occured. how solve these problem please help
2,441
