Problem uploading from 400h system to PG
gripster
Dec 2010
Londinium
40
413-5H redundant system
I can get online, monitor, even edit but cant upload to the PG, tried creating a new project, asks for rack/slot/ but cant find anything. Go through hardware config and get similar message after agreeing to unassign PG got a hardware config message, saying difference between DP/PN
so tried via rack 1 slot 3 instead of rack 0 slot 3. even tried entering IP directly. but just returns nothing.
Any suggestions as to where I have c****d up?
Ethernet, yes tried the little button, just led me back to this rack and slot option again, had Siemens on the phone, they were perplexed.
Sure it is something I have done wrong, but a little concerned as had to do full cold reset (remove and replace) the CPU in the rack 1 (rack 0 healthy and online) I have a test system back at base and have the same issue, so kind of pointing towards way I have configured something on the laptop?
On the laptop? Strange that I can get on line to monitor though as surely the traffic is both ways? Will try anyway though. Thank you
Hi all, Im stuck trying to support a client with Motorola ACE.. I was able to upload all of the other sites to STS but one. Im working remotely...
115
I'm starting learning ladder programming. I bought the FX3U kit + coolmay HMI from aliexpress. I'm doing basic testing and uploading codes. I...
57
3,929
Hi dears I am facing problem during program upload on S7 200 (226 cpu)microwin 4 sp9 closes on 100% I try to upload data blocks, its ok, System...
2,454
Hi all, I'm hardly a Siemens expert, and am struggling with a conversion I'm working on right now. A system was purchased at auction, and I'm...
1,859
I'm trying to upload a program from the aforementioned HMI but I've failed so far. I have an EasyBuilder pro and using Ethernet cable. From the...
8,006
