S7 200 PLC Program uploading problem
aliturk
Apr 2020
kpk
Hi dears I am facing problem during program upload on S7 200 (226 cpu)microwin 4 sp9 closes on 100% I try to upload data blocks, its ok, System locks its ok, but program block did not upload, although progress goes upto 100%, then microwin closes.
my cpu is not chinees version, please help me
s7 200 program uploading problem
thanks for reply
I am using window XP SP3
Microwin V4 SP9
CPU 6ES7 216-2BD23-0XB0.
No password on CPU is set, and it is not CN version
When I start to upload program from PLC to PC communication established successfully, when it goes up to 100% microwin closes.
I tries separately data block as well as system lock uploaded successful but program block reached to 100% microwin closes.
please help me out
I seem to remember a long ago I had a regular CPU ("non-CN"... non-chinese CPU) where I still had to change the microwin language to Chinese to upload.
Otherwise, if you have the install disc of Microwin you can try the following:
Reinstall Microwin SP9
Reinstall but install with SP8
Install on another computer or virtual machine
Haven't you this version ''4.0.9.25'' step 7 microwin?
S7 200 plc program uploading issue
Thanks dear for reply,
I have tried with microwin V4, SP8 problem not solved, then try microwin v4, sP9, again same behaviour. MY CPU is germany.
I have tried to change microwin language as well as system regional language to chinees but no result.
Welcome brother. If the CPU is made by Germany then you must regional language setting Germany. Otherwise not work.
For TIA Portal13 on SCL.I can not find anything for 1200 series :confused: Only for 300/400
2,493
Hi Folks, I need to try and back up the PC 200 ZE EPROM program from a Bosch machine. I have no software at the moment or Cables or manuals...
2,131
dear , I am writing a program for 1200 plc for printing using AWA instruction it is printing correctly but data words values are not coming...
1,429
i Have an S7-200 plc and an single pushbutton. when pushbutton is pressed for the first time output 1 should activate. when pushbutton is...
3,727
I am an undergrad electrical engineering student. I need a 200 components OMRON PLC program. I have been searching for 1,5 months, but I still...
7,539
