Problem with EDS module? - RSLogix and Sick FlexiSoft
JohanM
Sep 2015
Terchová
53
Hi guys. I have some weird problem. Im trying to add Sick FlexiSoft GENT (ETH/IP) module to my hardware configuration, but it show my message like this: "At least one connection must be configured for this device".. Its looks like the RSLogix cant read connection information from EDS file. It is possible or there is something else? When I open EDS file with notepad, I can see row named "Connection Manager" and there are some datas. I compared it with other EDS for another hw and its look ok.. hmm.. What can I try?.. Thank you so much... I am running on RSLogix 20 MINI and RSLinx 3.80
  • EDS_file_FX0_GENT00000_DC0001592.ZIP
Check the Connection tab in the ethernet module properties window. I'm not sure, but my best guess would be that you haven't configured any input or output data instances.
You don't need an eds for the GENT module as it has a built in server that will read and write its status to your PLC. You specify which tags you want to read/write in the GENT configuration. The PLC only needs to have the tag arrays present for it to read/write them.
Here are some screen shots:
I'm using Studio5000, 1769-L33ERMS Compact GuardLogix 5370 Safety Controller, version 30,
And the Balluff block, as per my original post about this problem:
The weird part is that when I import a Balluff block from another program I did using a different laptop, I can select some things in the Module Definitions screen:
The problem seems to be when I setup the new EDS files on this laptop. They are not usable.
Hmm. So, are the EDS files created by the Balluff software somehow? I've not used Balluff I/O before.
Huh. I'm just stabbing in the dark here, because again I've never used Balluff I/O, but the next thing I'd try is a repair on the FT Services Platform (from Control Panel>Programs & Features). Failing that, an uninstall/reinstall of RSLinx. Can you uninstall/reinstall EDS files as well? I've never had to try...
Hello everyone, I'm having issues with connected components. I got a new laptop and I installed all the RA programs I need without problem. I was...
345
We have a problem opening a project in Tia v17 (Scout Tia v5.4 sp3) : Totally Integrated Automation Portal has encountered a problem and needs to...
4,135
OK, Looking for a bit of assistance here. I have Studio 5000 Logix Designer software V24 running on my PC and laptop. In my MAIN PLC program I...
2,580
Hey guys, Today while installing all my rockwell software on my new VMware WinXP, on almost every installation they were asking me to: " Log On...
4,801
I have an Allen Bradley dialogue plus connected via DeviceNet to SCANport [111]. version 2.1 I am struggling downloading the eds file. Tried to...
2,571
