hi, everybody
I have a ge fanuc 90-30 base 10 slot ic693apu302, it is connected to the plc via a 25 pin cable connecting the plc to the pc through a horner electric pcif-30 card, the problem is that the card has an address of 300 (the switches are in position 000001), when i run the machine the pcif card is not read, it gives me an error message of "horner electric pcif card not found", inorder to read the card i do the following:
1.shutdown the m/c
2.put the dip switches all in zero position(000000).
3. run the m/c.
4.after the error message appears, i modify the last dip switch to be 1 (000001).
the m/c runs well. So, i need a way for the pc to keep the address of the pcif card, inorder not to make the above sequence of operation everytime i turn off the m/c.
thanks at all.
1.shutdown the m/c
3. run the m/c.
thanks at all.
