Problem with Mitsubishi CC-Link PT100 module
kwnstantinos
Mar 2011
Greece
Dear gentlemen,
I have installed a Mitsubishi Q series PLC with a CC-Link network, where I use a number of CC-link modules(Digital Inputs, PT100 and thermocouple).
I have programmed this project using GX IEC 7.04, and I am using the standard Mitsubishi function blocks for every module.
All modules work fine and deliver data to the PLC, except PT-100 modules, which do not write anything to the PLC registers.
The PT-100 CCLink module that I use is AJ65SBT-64RD3, which is the new compact version of AJ65BT-64RD3 module.
I use the function block of AJ65BT-64RD3, because there is no fuction block for AJ65SBT-64RD3, but I believe there cannot be any problem with that, since it is just a compact version of the AJ65BT-64RD3.
If anyone have a clue, please contact me.
Please note that the system is already installed on a ship, and it is not very easy for me to visit and make test every day.
Thanks.
Konstantinos
Hi All,I had done up a PLC program which requires CC-Link. Program has no problem but when i try to write into the HMI (Mitsubishi GT15) the lamp...
2,398
Hello I am writing to request assistance with obtaining a specific GSD file for our Mitsubishi inverter type A800-E, which is connected to our...
440
Hi, I have a Mitsubishi FX5U PLC where I cannot established communication via ethernet port of my computer. Search all videos and follow all the...
1,283
Some time ago, I looked at a form of indirect addressing on Q series PLC's, the normal way is to use the "Z" registers as an indirect pointer, so...
2,008
I have gotten help with some issues in the past on this forum, and I'm hoping someone can help me again. My company is an OEM that used the...
963
