Problem with RsNetWorx
Tarlo
Aug 2011
Roma
32
Hi all again.
I finally configured a deviceNet Network between a l32e Controller with 1769-SDN and an AC Drive Bulletin Analog 160 SF1 with module 160-DN2.
I configured the network's nodes and nothing is in fault. But when i upload the drive's parameters i receive an error: "Impossibile trovare membro" (means "impossible find members") and the parameters' list doesn't update and i can't download new value of the parameters.
I have thought that even this is an eds file problem so i download the proper file from rockwell's site and i updates it into the rsnetworx but nothing is changed.
I attached a screen of the error.
Hope that you can help me again.
Thank you
Update: I noticed that in the General tab, clicking the arrow appears "device identity 1" and that there is an unknown device. The revision number (3.002) is the same as the DeviceNet module drives the 160-DN2.
I tried to search the eds files for the 160-dn2 but it seems not to exist.
This is probably due to an incompatibility between RSNetworx and RSLinx Classic.
I know that Version 8 of RSNetworx and Version 2.54 of RSLinx Classic will have this problem.
Ideally, run the current releases: RSNetworx v10 and RSLinx 2.57 or 2.58.
I have installed RSNetworx v. 10 and rslinx v. 2.58 and works all. I spend two days of my life for a silly problem.
Thank you again Ken. 🍻
Hello. If anybody has seen this before and could provide some clues I and some other people would be extremely grateful if you can share such...
1,341
Hi there, I got a headache working with Devicenet network and I finally decided to post my issue. I have Compactlogix with Devicenet scanner...
18
5,736
Hi All! I added a combination I/O module 1794 IE4 XOE2/B to the end of 1794 RIO devicenet node. In RSNetworx for Devicenet V11 (CPR9) for some...
5,163
Can anyone help me? I got a problem in registering devices on RSNetworx for deviceNet (Revision 10.01). Pls refer to my attachment pictures...
2,781
Hi everyone! I have problem installing my new version of RSNetworx V21. During the installation, I have a message : ''Unable to continue...
1,701
