RsNetworx Problem
minaykha
Apr 2009
singapore
96
Can anyone help me?
I got a problem in registering devices on RSNetworx for deviceNet (Revision 10.01).
Pls refer to my attachment pictures.
1. pix 1, i download EDS file for rockwell website and used EDS wizard to register it.
2. pix 2, there is an error in EDS file installation Test Results ( I not sure what is this error ).
3. pix 3, EDS file registration was successful but the device is not registered on my PC.
Pls help!
Hi
Have you upgraded to ver 20 or ver 21 of logix lately
If you have then best to upgrade network to verv20
I have trouble when I upgrade to ver 20 and 21 has changed
How eds files are handled
Donnchadh
Hi Widelto/Donnchadh,
Rslogix5000(V20),Rslinx(V2.59)and FTview(V7)are installed on my PC,before i install RSNetworx for deviceNet.
Recently, i installed RSNetworx for Devicenet(V10) and configure the new system.Then i found this issue.
Actually, one of my VMware player running fine with same software and version.Only the difference is VMware using FTview version6.
I think, something wrong with my PC.
It's not your PC that's at fault. Rockwell have change how the eds files are handled with the latest versions of software so you'll need to install RS Networx for devicenet V21.
There's alot of info on Rockwell's knowledge base about this problem, check out article 530781.
Hello. If anybody has seen this before and could provide some clues I and some other people would be extremely grateful if you can share such...
1,341
Hi there, I got a headache working with Devicenet network and I finally decided to post my issue. I have Compactlogix with Devicenet scanner...
18
5,735
Hi All! I added a combination I/O module 1794 IE4 XOE2/B to the end of 1794 RIO devicenet node. In RSNetworx for Devicenet V11 (CPR9) for some...
5,163
Hi everyone! I have problem installing my new version of RSNetworx V21. During the installation, I have a message : ''Unable to continue...
1,701
Hi all again. I finally configured a deviceNet Network between a l32e Controller with 1769-SDN and an AC Drive Bulletin Analog 160 SF1 with module...
1,746
