Problem With Tags in FActory Talk ME Runtime On PC
danish
Oct 2015
Pakistan
Above is the Network Architecture View attachment 38527
Allen Bradely PLC is Communicating with HMI and PC. HMI is Working fine. Runtime on PC has a problem with Tags. Runtime Snaps are pasted for Clarification.
Runtime ON PC View attachment 38528
TAG Description AI_00: should be Compressor Oil Pressure (PT-3966)
[FONT=&quot]
[/FONT]
Runtime on HMI View attachment 38529
Please Suggest if some thing is missing with the Tags.
Are you using FTView ME Station on the PC?
You need to "replace communications" when you open/run the MER file.
Don't forget that all important "Copy from Design to Runtime" button in the communications setup if you have made any local changes to the device shortcuts.
Another thing is that you can't just hit the play button in FT and get data that is passed in through a parameter file (which is what I suspect might be happening here). If you configuration PC cannot see the comms protocol it also wont work (eg your PLC is on DH+ or something).
Thanks all for ur feedback. i have solved the issue it require to restore RECIPE Files and Download them in HMI Memory. Once i downloaded Recipe files all Tags were fine as HMI Tags.
Danish
Hello Guys, I am Facing a problem with Factory Talk ME Station Runtime on PC. I have loaded same .mer file in HMI(PV-1000) & PC(Factory Talk ME...
2,417
Hi fella's, I had a search for an answer to this prior to posting. I am using Factory Talk View Studio, machine edition V5.00.00 and when I...
10,536
Hi, This morning I attempted to add a good bit of communication between a few of our PLCs. For the most part, everything worked fine, except for...
354
I can view all Produced tags list in the project from Logic-->produced tags, can someone help me on how to view the consumed tag list ? Thanks in...
1,597
i have a serious problem with my wincc explorer RC Tags license every time i open the program i found the license tags 0 although i installed the...
2,264
