Problem with WinCC 2008 Flexible
Liam Moran
May 2011
Carlow
401
Hello all
I have set up Wincc 2008 Flexible Advanced on my laptop
but am experiencing some problems.
It is WinCC flexible 2008 SP3.
I am running Windows 7 professional 64 bit.
My problem is when I click on the Project tab, then click open I get the pop up window to select the location of the file to open.
As soon as I move the mouse pointer this dialog box disappears.
I tried using the alt keys and the keyboard keys to navigate without issue as far as I could,
without issue but as soon as I move the mouse I get the problem.
This is a new installation on this laptop, I already had WinCC 2008 SP2 running on an XP machine,
but I had to get the SP3 DVD to install on windows 7 64 bit. The installation went OK, licence transfer went OK,
but when I try to open one of my projects I get this problem.
Do any of you have any ideas how to fix this and keep a grumpy old man from getting grumpier :nodi:
Thanks in advance.
A bit of an update...
Right clicked on the WinCC icon and went into properties.
Selected to run in XP SP3 mode, and selected to run as an administrator.
Saved and reopened WinCC, an low and behold it worked as normal.
I wanted then to find out which setting fixed the issue, tried each in turn, and then deselected both settings and it still works ok.
Now I am really puzzled, but at least it works.
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,318
Dear all, I'm having problems trying to copy a screen with faceplate from one project to another. When I try to paste into project B from...
1,494
hello everybody: I have WinCC flexible problem, need help! WinCC flexible 2008 worked well before, but today it suddently has problem. when I...
1,219
I'm trying to migrate a ProTool program to WinCC Flexible 2008 Advanced and when I open WinCC and say open a ProTool project, I get 2 errors. The...
9,129
Hi guys, I have been working on a project where I use WinCC Flexible 2008 SP2, Runtime is on PC and my question is quite simple: I use many...
6,405
