problem with windows installer rslinx
jmrcalin
Sep 2005
barcelona
27
Hi!
I uninstall rslinx 2.40 and now if I install again it a error message appears: "1550 other instalation is running".
And if I install rslinx 2.20, I haven´t any problem, but when I try to update rslinx 2.41,then a error message appears: "there is a problem with windows installer package"
How can I update rslinx 2.20 to rslinx 2.40?
regards
I recall some similar problems around the 2.3 or 2.4 versions. There's probably an article on the Rockwell knowledgebase but what I did was use regedt to search the registry for any references to rslinx and delete them. Then install the new version.
I had this problem while trying to install RSLinx 2.43
This was a problem with different versions of Microsoft Installer running same time.
I fixed it by deleting all files in the TEMP folder.
Also look at the running processes to see if MSI.exe already running. You should shut it down.
Also try MS CleanUp utility:
Description of the Windows Installer CleanUp Utility: http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
RSLinx
This is a common problem. Go to Regedit and under edit click "find" and type in rslinx. Delete these keys. The uninstall utillity will not remove all keys for the program. If you ran uninstall without shutting linx down, it will not remove anything it finds in memory.
RsLinx does not "quit" when you exit the program. You must stop it before trying to uninstall it.
Bruce99 said:
Shutting Linx down will require using task manager. Closing the program as Lance stated, does not stop the process.
RSLinx Lunch Control Panel will stop service. It's not necessary to use task manager
linx shutdown
I tried the launch utillity, and like the uninstall utillity, it did not work very well. I now always use task manager. It works most of the time, but still not 100%. After using the launch utillity I used uninstall and then tried to reinstall on a different partition. It failed.
Here is the solution:
Turn off RSI services
You may be able to install RSLinx by disabling the services listed below.
    • 1. FactoryTalkCE
      2. FactoryTalkReader
      3. RockwellApplication Services
      4. RockwellDirectoryMultiplexor
      5. RockwellDirectoryServer
      6. RockwellEvent Multiplexor
      7. RockwellEventSever
      8. RockwellHMIActivityLogger
      9. RockwellHMIDiagnostics
After stopping the services, reboot the PC. The services should come up stopped.
Try to install RSLinx. If successful, reboot and then return the services to their original settings.
that is the best solution to re-install rslink if it doesn´t install correctly.
regards
Seems like this tool only could find device when the windows has internet access. Once I set Advanced TCP/IP Setting to Enable NetBIOS over...
7,842
Hi everyone I am trying to install Rockwell automation software on my computer, which is curently running MS Windows 7 32 bit. Surprisingly, I am...
11,224
Does anyone else have the problem of RS5000.exe staying resident in memory after closing the software? I look in the Windows taskmanager and find...
2,238
Does anyone know if there is some unrepairable conflict problem using a PIC box (1747-PIC) with Windows XP? I can't communicate at all using the...
1,654
Hello, I tried communicating my PLC S7-300 with CP-5511 card in my laptop using Windows 98. I was successful. But with the same card I am unable...
5,635
