Problems with PanelView Plus 700 upgrade
Jan 2007
Malmö
I have performed a firmware upgrade of a Allen-Bradley PanelView Plus 700 terminal from version 3.00.03.65 to 3.10.00.38.
After downloading the new version from the Firmware Upgrade wizard in RSView Studio I get an OK message on the PC asking if I want to restart the terminal.
After answering OK, the terminal restarts but even since the restart, the display is all black and I can no longer access the terminal from any PC program.
The COMM led is green and the FAULT led is not lit.
I have tried the reset and default switches on the terminal but no result. The display is still dead.
Is there any other way of reseting the terminal?
Has anyone accounted this problem?
I did that once, we ended up returing the unit to AB. It was a long time ago. If i recall there is a hardware issue that a 3.0 terminal doesn't take the 3.1 firmware properly.
Drewcrew6
I belive that when upgrading from version 3.0 to 3.1, there was a Microsoft Windows CE upgrade that had to be completed before upgrading the firmware.
I'd recommend contacting your local distributor to confirm this.
Rick
Hi there, Maybe I am overthinking this issue, but here is what I have going on. I have a program running for a water valve on a DI system. We...
459
We had to replace a bad Panelview plus 6. It was running factorytalk v5 and kepware v4. This unit is talking to two AB PLC 5s over DH+ and 3 TI...
1,836
I have a new 10" PVP6 installed on our DH+ network (replaced legacy PV 1000). Since installing when I connect to the PLC with RSLinx (REV 3.60.00...
1,797
What is the proper format for an alarm trigger when setting up a panelview plus 1000 that is connected with a slc 500 with a 5/04 processor. This...
4,692
We have a Panelview Plus 1000 communicating with a warm backup CompactLogix (L32Es with a 1769-SDN card) pair over DeviceNet. At this stage, the...
2,867
