Process Knowledge - Need help !
Tomsci
Nov 2004
Dear all,
I am looking for some websites / books which will give me good understanding of the control strategies implemented in process industries.
For every plant, there will be equipemtns such as boilers , compressors , dryers etc..I want to know the functions of such equipments...their control strategies... with P&IDs, functional descriptions, logic descriptions etc..
eg: Boiler Control - 3 Element Control....etc..
Dryer Sequence Control
Anti Surge Control for Compressors
Thanks in advance,
tomsci
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
118
Hi All, Im using Cimplicity 8.2. after the last restart Server Scada, the PTDL_RP process can not running. so Process can not be login to database...
184
Hello parky, goghie, Brian and all of you who kindly come to help when I get stuck. I cannot look into the clock issue that parki has written for...
890
Hi, When I use an interrupt OB (let's say OB38 which is processed every 10ms), does it read the state of the inputs at the time it is called, or...
18
2,500
I have a question about process interlock naming. I want to hear opinions, as well as if there is a relevant standard. When naming specific...
693
