Produced/Comsumed across Ethernet network error
Sydney
Nov 2011
Central Coast of California
61
Hi all
I'm trying to add a Consumed Tag in a 1756-L63 across a EtherNet network to another 1756-L63 in a second chassis. I know the controller 1756-L63 producing the tags is working because there is a 1756-L1 consuming the same data in the same chassis.
I have the two Ethernet cards connected through a router and my laptop is connected wirelessly to the router for programming.
I'm getting a connection error (16#0203) Connection Timed Out on the 1756-L63 in the I/O configuration tree of the consuming controller.
My question is can I use an router or does this connection require a switch to connect between the two EtherNet cards. One card is a 1756-ENBT/A and the other is a 1756/ENET/B.
Also I made sure the producer had enough consumers.
In general a system with multiple Consumers will use IP Multicast, which means that the devices need to be able to reach each other over an ordinary Layer 2 switch or a network otherwise set up to transport multicast traffic.
Does your router have a built-in switch and the devices are all on the same logical and physical LAN, or is the traffic actually crossing the router from one subnet to another ?
Even the old 1756-ENET/B should be capable of Producing tags over EtherNet/IP, but they had a relatively small number of available connections, so you might want to check its diagnostic webpage.
And I'm not sure that the 1756-ENET supported Unicast connections even if it was used with a v16 or newer controller.
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
176
Hi I have been knocking my head against the wall trying to figure out why these two plcs won't talk with Produced and Consumed Tags data. The...
488
Hello all. I have a 1769-L16 that I inserted a 1769-L35E into. I was expecting it to create module defined tags automatically in my controller...
1,818
Hi, Can a tag configured as a Produced or Consumed tag be read or written to with Explicit Messaging? Context: we are retrofitting an AV system...
2,264
I have a "Master" 5069-L306ER PLC that is going to hold 1 produced tag running out to 9 consumer PLCs. The L306ER only supports 8 ethernet...
2,583
