Product indexing on Controllogix
asterof
May 2007
Califonia
554
Any one have any code for indexing two conveyors to feed one
I have two conveyors side by side feeding one conveyor using a Y conveyor.
Of course the problem is when two packages reach the Y at the same time
the jam each other. I have a photo eye located at the start of each Y side
and one on the Y single leg. I am trying to determine when package gets there first, hold
the second conveyor till the package off the first conveyor passes the photo eye in the
Single section of the Y, then release one from the second conveyor while holding the
first conveyor and basically indexing back and forth.
Any code or detailed ideas would be helpful.
Hello All, I'm looking for some opinions and Ideas for guarding the product entrance of a palletizing robot cell. Please see the attached...
511
Respected Members; I am going to design the PLC control system. The requirement as under: 1. Input/ Out put modules are SIL 2 certified. 24...
421
I've got an issue opening a project in TIA Portal v16. When the file is opening, I get the message that says "Optional products used in the...
727
I am new to Siemens, and just looking into their HMI software. Does Siemens have a product similar to FactoryTalk View SE? I am looking to have...
1,755
I am speccing out a system for some burner controls and the customer has two SLC500s that will need to be upgraded. There is no distributed IO. I...
25
6,590
