Product Service Advisory RS ControlLogix / FlexLogix
JERA
Feb 2006
Copenhagen
320
Hi
If you have a ControlLogix Controller 1756-L55 firmware Revision 15.03 and 15.04 or a FlexLogix Controller 1794-L34 firmware Revision 15.03, 15.04, and 15.05 read the attached.
There is a failure in the firmware so after approximately 3 to 4 months of continuous operation, 1756-L55 and 1794-L34 controllers at the firmware revisions listed above experience a non-recoverable major fault.
Continuous operation is defined as the controller being powered up in any mode (Program, Run, Remote, or Remote Run).
JERA
Thanks for posting.
That is not a new service bulletin though. That problem was identified around a year ago. The date on the document you posted is november of 2006.
I had to rev. up several plc's to fix it at my facility.
RSL
Look upyou maybe have a problem!
Hi
I know that it is no new service bulletin, and it was only for information.
The reason for I posted it, was that I have a new plant controlled by FlexLogix and it was made with RSLogix 5000 ver. 15, so the firmware for the system was 15.3 and I got the problems.
I got this service bulletin from Rockwell tech support, and fixed the problem with a firmware upgrade.
So for information for all them there (like me) have made a new project in ver. 15, look here you maybe have a problem.
Okay, I think we had this issue, but I am a little bit unsure about our firmware revision.
On the controller properties page it shows 15.3, not 15.03. Are these one and the same?
I have been all over ab.com looking for a list of firmware numbers for an hour. I find some references to 15.03 and some references to 15.3 but never both in the same document...
Thanks in advance.
Best guess = Upgrade
After checking Rockwell Flash Firmware Updates page, I will guess that you are in the danger zone, because the only availably firmware version in version 15 is:
1794-L34 ver. 15.06
1756-L55 ver. 15.05
So if you have a 15.3 version I will upgrade, but you can check with Rockwell Tech support.
If you contact Rockwell, do have the serial number for the processor ready, it will help them to say yes/no to a firmware upgrade.
I hate when I get these....but at least I get them.
5,898
This one just bit our *** today. And our AB rep hadn't even heard of it. Search the knowledge base for "ACIG 2007-05-002" Here's a quick...
3,165
PRODUCT SERVICE ADVISORY 1768-L43 CompactLogix Controller Series A, Catalog Revision A01, Firmware Revision 15.07 Ref: ACIG 2007-02-001 Date...
15,174
A little change of pace, from some of the ranting about bad companies, poor products, and lousy support.....(not that it's been un justified) I...
4,976
Hello All, I'm looking for some opinions and Ideas for guarding the product entrance of a palletizing robot cell. Please see the attached...
508
