Production Schedule into AB PLC communication
RRCPM
Mar 2020
Texas
Hello,
Does anyone know how to transfer a production schedule data into an Allen Bradley CompactLogix PLC?
We have a machine that slices 40-50” foam blocks horizontally in several 2”, 3” or 4” thicknesses. The operator inputs the required cutting thickness on a Redlion HMI. For example, a 50” block can be cut around 25 times with a set thickness of 2”.
Would it be possible to have this production schedule with the thickness transferred automatically into the PLC without depending on the operator to input the required cut thickness manually.
Basically, I would like to grab this production schedule data that has the thickness and block sizes, and transfer automatically into to the PLC. The production schedule is currently on internal web server and I want to grab it and transfer to the PLC.
Would anyone know if this is possible?
Thank you!
You will need to use something called an Manufacturing Execution System.
It's basically a system which works together with a database to provide instructions to the equipment.
You can write your own MES. Depending on how simple you want it to be, you can do it in Excel using RSLinx Professional.
Or you can use something more complicated which has an OPC, DataBase as well as a PLC system. DB>Scripting>OPC>Scripting>PLC.
Depends on what you would like. Can you share what your average productions schedule is like? Is it in the form of a paper record, or a database, or an excel?
Hi! I'm wondering if PLCs are used for small-scale production. I've got four machines doing different things with textiles, and I'm exploring the...
1,342
Hi, Wanted some opinion about storing production code for projects. What is a proper strategy for it? For example if you use Studio 5000, a...
4,319
Does anybody out there have access to a marshmallow production facility? A science education YouTube channel that I follow is interested in doing...
2,041
Hi, Looking to update EN2T firmware for systems that are in production. We are expecting to lose comms systems that have that card and also to...
1,967
Hi! My client has requested an energy monitoring system with a capability of entering production of each machine by the operator. The system must...
2,155
