Energy monitoring and Production monitoring system
nuwan
Sep 2013
Moratuwa
30
Hi! My client has requested an energy monitoring system with a capability of entering production of each machine by the operator. The system must be able to log the energy data. He runs a shoe factory and to feed the daily production he is requesting a web interface. (This is because, according to him, there is no room for sensors inside machines. )
I selected Schneider Com'X 510 but manually entering the daily production is what I am skeptical about.
Could someone please help ?
I'm assuming 'Cheap'?
If you are planning to log the production data to the Schneider, any HMI should allow production entry. Some of those HMIs can communicate OPC to Excel.
There are also a few solutions for bringing registers from the Schneider to an Excel sheet for reporting
The interface for entering and correcting production data should not be under-estimated. It will take a few tries to get it so they like it!
Yes it must be cheap. :nodi:
But I believe Com'X won't support HMIs. But I think you are suggesting me to use a PLC instead of Schneider Com'X. Right?
I referred to the Com`X as a PLC. Sorry, wrong name. More like an electric meter, or a data server ... but still not quite.
I went through the settings, and like most things, it`s not quite what I remember. :(
I should preface this with the fact that I have never used a Com`X. I just investigated using one a while ago. So I have no idea if these ideas will work. With that said, here`s what I`d try.
You`d have to test this - the idea is to define an `extra` external meter (your normal meters of course, but this one is just to store your production data) at a spare address on modbus, then use the registers that the Com`X allocates to that meter to store your production data. You would need to be able to write to those registers from the Com`X web interface ... again, something to test. I don`t know how flexible the Com`X interface is.
If it works, there area a couple of positives:
- an export of data from the Com`X will put ALL of your data into one CSV file, from the web browser
- no external database to maintain, back up, etc
The only negative on the data is that it will require some custom reporting in Excel. You can make that as complex or as simple as you like.
Since this sounds very useful ... it`s likely not possible in the Com`X web interface. But it doesn`t hurt to try.
Comx has in built webserver, not sure why you would want it to support an HMI ?
Also in my experience its an awful bit of hardware and software design, unreliable, buggy, slow, hard to configure, we swore never again...
Hi everybody, in my new project have to use energy monitoring device Installation pretty much simple ...
1,597
Did a forum search but did not see anything recent. What are people using to monitor energy usage at their facility? I am being tasked with...
31
6,793
Hi, i cant establish communication between fatek plc with an energy meter, both capable for modbus tcp, i did with modscan but fatek plc does not...
151
I want to calculate the energy consumed from instantaneous power. Can this be done using the TOT block with timebase set to Hour?
693
Hi All, We are planning Establish communication between Power Energy Meter (Schneider PM5320) with Rockwell PLC. I am unable to get the Assembly...
760
