Proface and S7-200
We've also connected the S7200 PPI interface to some GP377R's. We're still using and old version of GP Pro (V7.01E) in the Device setup just select the S7200 PPI interface and you can get a pinout of the cable you have to make up on their website.
Yes - the small displays are RS232 and need a gender change plug and an interface plug. The larger displays are RS485/MPI and just need the interface plug.
Available from your dealer. I can get the part numbers if you need them.
I use a length of profibus cable and two profibus plugs with internal terminating resistors. This also works with the small displays.
Is Proface is compatible with S7-200 plc, if yes then how to do it how to do it
Yes I have used AGP 3200 and 3300 connected via RS232/RS485 port. Software configurable port to enable RS485/MPI as markie suggests. The driver is selectable in GP ProEX. Proface even will send you the cable. As usual the HMI is the Master. Works and behaves very well.
i need HELP, Hello everyone i have a problem like this, i made just two buttons letter A and B in my Hmi proface AGP 3200 , and i make a simple...
1,859
anyone have Proface agp3302 hmi to micrologix 1200 communication cable diagram.....??
2,148
Hi everyone, I have an HMI Proface (AGP 330-T1-D24). I try to establish communication with my PLC S7-1200 (programmed by TIA Portal)but an...
3,589
Dear All, I want to communicate s7 200 and proface, so please provide the pin diagram of communication cable. Thanks in advance.
2,750
I've got GE Fanuc 90-30 CPU331 / CMM311 commreq problems. I've configured the 311 and the AGP3200 per GFK-0582D and Proface SNP-X comm manual for...
2,147
