Profibus Citect com problem
pacak
Sep 2006
Arad
65
Hello,
I have a communication problem between a Profibus network and Citect. There are 5 PLCs w/ CP343-5 Cps connected to a PC trough CP5613 A2.
Everything worked fine till last week, when I modified the reservation of connection resurses in the Hardwer Config of the PLCs from 1 PG, 1 OP, 12 others to 3 PG, 3 OP, 10 others. Since then the Citect pages are full of #COM-s and no data is coming from the PLCs.
In the Module Diagnostics window of the CPs it says that the "Module is available and o.k." I've put back the old numbers in the HW config (1,1,12) but it did not help.
I do not know where to look, what is the problem ?
Please help!
Problem solved!
Somebody told me to try to download a back-up version of the system data to the PLCs trough NetPro, and it worked (fortunately we make back-ups every week).
I still do not know the rootcause of the problem.
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
193
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
87
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
109
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
323
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
321
