I'm trying to setup a Profibus link between a CTI 2500-C200 PLC and a MTL 8507-BI-DP. I'm using FasTrack 505 Workshop V5.10.
I've tried a few different versions of the .GSD files from MTL as well as a newer one from GE who were looking after this product after MTL.
The configuration loads ok into the PLC, but the 8705 slave module always shows "Status: Offline" in the Profibus I/O configuration window.
STW231.1 is on (DP Operate)
STW231.6 is on (Slave Error)
All other bits of STW231 are off
The 8705 Slave Diagnostics window changes values when I connect/disconnect the profibus cable - so I know it's communicating.
With cable connected the diagnostics show:
"Slave not ready for data exchange = Yes"
"Incorrect parameterization = Yes"
"Slave has to be parameterized = Yes"
"Watchdog activated = Yes"
When I unplug the cable these all change to "No"
Has anyone had any success with configuring the MTL 8507 BIM?
regards, Phil
regards, Phil
