Profibus DP + Q02(H) Programming help
smithers
Jan 2005
England
25
Hello
I am currently trying to set up Profibus DP at my place of work.
The system comprises of:
Mitsubishi Q02(H) CPU;
Mitsubishi QJ71PB92D Profibus module;
Two HB-Therm heating units (type HB-140 D41) each with 4 seperate independant heating circuits.
The two heating units each possess one Profibus interface. Each Heating Unit uses 48 Words (96 Bytes) for plc to heating unit transmission (12 Words per heating circuit) with the 9th Word being broken down into its 16 bits. Also, each Heating Unit uses 80 Words (160 Bytes) for heating unit to plc transmission (20 Words per heating circuit) with the 9th, 19th, & 20th Words being broken down into their 16 bits.
I have configured the system using GX Configurator DP easily enough but I am a bit unsure as to how to write the plc code to enable me to read from/write to the heating units.
Any help would be appreciated.
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
194
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
87
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
109
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
323
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
321
