Profibus DP
Mclean
Apr 2003
A B C
©¸©¤©¤©¼©¸©¤©¤©¼©¸©¤
the connection is shown above,A is master,B & C are Slave.my question is if B lose power supply,could C be accessed?
Mclean,
If C has a different power supply to B, then there will be no problem accessing C via Profibus, as the profibus network is 'daisy chained' among the various devices on the network, so if B loses power it will not effect the comms between A and B
Paul
Typo!
Paul
I spotted my error 3 hours after making it!
That should have said - so if B loses power it will not effect the comms between A and C
Paul
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
196
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
91
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
112
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
327
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
322
