Profibus for dummies
cornbread
Feb 2007
madison, indiana
407
I'm doing my first project using profibus. I'm bringing in reading from Siemens 7SJ6 realy to a SLC500 via a prosoft card. Looking for some good docuements on how profibus addressing works. Any help would be greatly appreciated.
Got the GSD file and went thru the 146 set up but could not download the program kept getting error 401, I might not have the correct null cable. Will hit it again on Monday.
Finally got the communication working. The GSD file I was using was incorrect. 7SJ6 relay vers 3 and below take one file and Vers 4 and above take another. Now I just need to figure out SLC 500 sample program and hopefully I'm in the clear.
Profibus
help im new to this if a profibus cable is run under a panel for 3meters and is NOT segregated ie run with power cables what effect will this have on the network? the rest of the run is in trunking
thanks
Hi and welcome to the forum!
thanks
The point is that it is unpredictable. The power cables can generate el. noise in the bus cables and disturb such that the data signal is unreadable and the communication falls out sporacically.
There is a good way to fix it; using fibre optic with OLM's from Siemens https://www.automation.siemens.com/...nts/Pages/network-components.aspx?HTTPS=REDIR
Or these fiber plugs from Helmholz: http://www.ade.no/Produktsider/optopus.html
Or a Q&D way is to change the DP profile to 'user defined' and increase the retry limit to a (much) bigger number. The update time will increase, the data exchange will be more robust but your system will still be unpredictable.
Maybe you also should have a look at a Profibus analyzer f.x. from Procentec: http://www.procentec.com/profitrace2/
Kalle
We have a new system that uses a Beckhoff computer and CoDeSys. We also have an extensive Allen Bradley plc system CLX,PLC-5, and SLC 5-04 and...
3,257
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
196
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
91
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
112
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
327
