profibus i/o module
there is any need to use power supply to this module?
It needs 24V, but it doesn't need a special power supply just for its rack. If there is already a 24VDC power supply with enough capacity in the cabinet, you should be fine.
We've a 555-1106 with one remote base and three other PB devices. This base has a 505-6870 RBC, and three modules / IO cards. I am trying to add a...
1,590
Dear Sir, I have a healthy profibus communication between SIEMENS PLC S7 400 and Allen Bradley drive PF700 using 20-comm-p profibus dp module...
2,824
Hi, guys, how’s going? We have one production line that uses AB logix5000 as main PLC and FANUC robot, SIEMENS 840Dpl as slaves. The slaves...
1,646
I have an S7 1212 with CM1242-5 Profibus module configured in TIA V13 to connect to an S7 315 2DP Profibus master. The configuration is set up for...
2,601
I am experiencing an issue with the profibus modules on micromaster 420 drives. I would bet others are having the same problem so hopefully...
4,052
