Profibus Lightning Arrester
DCS_BOD
Jul 2007
Kent
26
Hi All,
When running armoured Profibus cable Outside of buildings, is it required to have a lightning arrester at both.
Eg. Going out of the builing and into the other building?
Any help apprieciated.
Regards
Robin
Robin
Speaking only for USA I do not believe lightning protection is required in all installations.
If you are in a high probability area then it may be a good idea. I think you will find that the emphasis is on protecting the building and not each individual system. If you "attract" a strike and bleed it off to another area the building is protected. I believe in some cases lightning arrestors are placed on poles adjacent to buildings to achieve this.
There are protectors for power wiring TV etc etc.
Look up lightning arrestor etc on Google to learn more which is what I did to learn what little I know. We are low probable in Seattle so we dont worry about it that much.
Dan Bentler
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
194
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
87
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
109
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
324
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
321
