ProfiBus Link Issue between two S7-300 PLC's
EHIRL
Mar 2013
Ireland
Hi All,
As part of a bigger project and not being too familiar with S7 I'm trying to send & receive data from datablocks over Profibus between a 315-2DP (Master) and a 313 with a CP342-5 Card (Slave). There is a Siemens Document details most of this and there is a lot of info on tips for communicating with the 342-5, all which I have examined.
At the moment everything looks good (No fault lights or diagnostic issues) The data transfer simply isn't occurring by looking at the datablocks online and I'm unsure why. The code can be downloaded at http://code.google.com/p/plc-code/downloads/list (just to big to upload here) below if anyone is interested and is bare-bones containing only the essentials, I imagine its a configuration issue.......
I Have solved this problem, I'm not too sure where the issue was but when I simply started from scratch again it all came together nicely, perhaps some helpful notes to anyone doing the same:
No matter what I couldn't send bytes but could send words so maybe try that 1st
This https://support.automation.siemens....slib.csinfo&lang=en&objid=6518938&caller=view link proved helpful but fell short in some parts for those not experienced. Also some of the code is in German so I & Q change to A & E I think it was.
PM me and I'll send on code if I can dig it out.
Hi, On a project, i have to assess the possibilities of communication directly from a Labview application on a computer. Profibus: you need a...
3,291
Dear all, In the past I have used DP/PA Links with Siemens PLCs. As both the Link and the PLC was from the same vendor, ther was no trouble...
3,109
For one of the projects, Customer has Profibus Network as below, Profibus Master 1 - PRM Module (Schneider) addressed (1) Profibs Master 2 -...
3,343
Hi all, Im using a S7-319 PLC and on the profibus network i have a IM153 (6ES7 153-2BA02-0xb0) connected to this i then have 2 PA Couplers FDC...
2,908
Hello All, Does anyone here have any experience with a Mitsubishi Q series and Siemens 318-2 profibus DP link? I have the Siemens setup as master...
2,764
