Siemens S7 & Profibus PA Link HELP
Coops
Dec 2004
103
Hi all,
Im using a S7-319 PLC and on the profibus network i have a IM153 (6ES7 153-2BA02-0xb0) connected to this i then have 2 PA Couplers FDC 157-0 (6ES7 157-0AC83-0XA0). These couplers are programmed up to have coupler redundancy and are both connected on the end of the same PA network (one at the start/ one at the end). There are a couple of siemens level and flow devices on the PA network.
The Problem: When i just have one PA coupler active the network runs great but as soon as i turn the other one on i get intermittent problems with devices dropping on and off the bus. It doesnt matter which coupler i turn off i get the problem with both devices. BUT as soon as i turn one off the network runs fine, it seems as if they are fighting to take ownership of the network, I would expect one of them to become master and one to sit there until a fault occurs but it dont. The couplers are only setup using S7-Harware manager. The PA field devices are connected up using ASD splitter boxes by Siemens.
Any help is much appreciated.
Paul
Dear all, In the past I have used DP/PA Links with Siemens PLCs. As both the Link and the PLC was from the same vendor, ther was no trouble...
3,109
For one of the projects, Customer has Profibus Network as below, Profibus Master 1 - PRM Module (Schneider) addressed (1) Profibs Master 2 -...
3,343
Hello All, Does anyone here have any experience with a Mitsubishi Q series and Siemens 318-2 profibus DP link? I have the Siemens setup as master...
2,764
Hi, I have a Prosoft profibus master module (for control logix PLC) and the Siemens IM153-2 DP / PA link module (and the IM157 PA Coupler)...
6,592
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
557
