Profibus problems
clintb
Sep 2005
Melbourne
Hello all,
I am having problems very similar to alex_d, I am trying to setup a profibus DP network that will communicate between one pc loaded with wincc scada software and a siemens CPU314C-2DP plc and also a mentor VSD, I have tried many manuals and seem to have no success but just errors. If anyone has an tricks or good resources they would be very much appreciated.
first u must have the gsd file for the drive u are using
install it in the hardware configuration
click on the object in the hardware configuration and u will have section with parameter assignement
from the vsd manual u will find the pnu for the item u need , write it in front each item
now your hardware configuration is ready
in the program u call the parameter by the cooresponding piw
note , that u might need some conversion and scaling to have the wright reading
i had a document for connection to sipart , i will try to find it and send it to u
finally i was able to attach the files
these are a document by siemens describing the sipart dr linking and a hardware configuration for a project i have already made
Hi all, I will try and give as much info as possible to begin with but I am a graduate thrown in at the deep end so bear with me please. Upon...
5,314
I have a S7-313-2dp processor and I ma trying to connect via profibus to a sew mdx61b. I can send data to and recieve from the drive but it will...
3,923
hallo i am having a problem the wago module and the cpu are connected with each other and the adresses are oke. but my tia portal keeps giving me...
4,688
Hi, i got a 6RA70 with a S7-315 dp/pn. The profibus is working I can see the status word in the PLC And the controlword is received to CB in the...
1,538
Hi, I have a new Siemens 400H-CPU. On the rack there is a power module, a CPU and an ethernet card. I need to download the hardware...
1,994
