Profibus Scanner( SST profibus Confirgation Tool)
Feb 2013
jharsuguda
20
We have recently installed SSt Profibus Confirgation Tool. But could not go online.
We have SST-PFB-CLX-RLL module in remote backplane. Our PC is connected to PLC through Ethernet switch. The remote backplane containing SST-PFB-CLX-RLL module is connected to the Backplane having ethernet module through controlnet. While selecting RSLinx in SST profibus confirgation tool, it showed me the following error "DTL_INIT Failed"
I pressed OK and continued to enter the network properties.I entered the following settings:
Slot no 01 /*as SST-PFB-CLX-RLL module is in slot 01
Bridge IP 10.118.37.86 /* ip address of ethernet module
CIP path 01 02 02 06 01 00 /* generated by software on clicking edit path, then adding PC to ENBT then CNB to CNB.
Driver name: AB_ ETHIP-1 /* as in RSLinx
Then I got the error " failed to read Module ID"
I have also attached the screenshots of the errors and the process & settings, and also the the RSlinx network
Can any one help me solve my issue......
This post is rather old, but I just ran into the same problem.
The solution is that you need to have RS Linx Gateway to connect the SST software. RS Linx Lite will throw the errors.
Hello,
I know that some time have passed since you posted this thread,
but my be you still have the configuration tool and you can send me link for SST Profibus configuration tool?
Hi experts! Is there a compatibility of firmware version between PLC L72s and SST-PB3-CLX-RLL profibus scanner ? I upgraded my PLC firmware from...
1,227
Hi guys, I am in need of some advice from people with experience with the above. I am currently replacing a client's SST-PFB-CLX profibus...
6,455
i am looking for a profibus scanner SST-PFB-SLC Version 1.0 for SLC 5/03, but it's hard to find. I see the same model number, but version 2.0 on...
2,507
Hallo, I need some help with the conection for allen bradley CPU and sst profibus scanner. I want to go with the sst scanner to the siemens dp/asi...
7,415
Just to clarify my query posted recently, we are trying to communicate to the SST-PFB-CLX profibus scanner over ControlNet and need a EDS file to...
7,507
