Profibus w/ APV CU2/CU3 Devices
richardwal
Jan 2008
California
18
Folks,
We have an older system that was migrated from an SLC to a ControlLogix processor. With this upgrade we also switch, not surprisingly, from an SST SLC Master to a SST CLX Master. All of our devices on this network are old APV Delta CU2 modules...as well as a few Delta CU3 modules masquerading as CU2s. We used to have a piece of software from APV named Valve-Net Toolbox. This software is no longer functional. I've been unable to find any replacement for this software. Does anyone have any good suggestions? The connection was straight into a repeater, I'd love to find something that will allow access to the valve information via the PFB-CLX card in the PLC. I'm also failing miserably when it comes to more information available from the CU2 units. I'd be happy if I could query the information from the device with the PLC. I'm just not finding any information on these units whatsoever.
Thanks for any and all help,
Richard
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
197
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
93
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
114
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
328
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
326
