Profibus
pgustavsson
Jan 2006
Tranås
I wonder if anyone know if it´s possible to use a timestamp
when you send a profibus telegram.
The reason for this is, I have a lot of servo inverters
and I would like to read out the temperature and the load of each motor.But though the profibus is slightly overloaded, I dont find it necessary to collect the information more then e.g once every 5 min.
Per gustavsson
Yes , but he is asking you how much data you are examining ? how many words you are reading and writing to each device ?
We are using a CPU 414-3 and on this one there´s 2 profibus masters.
One master is dedicated for the servo inverters (92 of them)
and the other master is dedicated for I/O moduls and HMI applications.
(88 moduls of them)
Data transfer
Hi 10baseT !
I think that right now we are using 3 words for transmiting and 3 words for reciving information from the drives.(masterdrive + and masterdrive)
The other master is controling the I/O ´s and on this one we don´t need to make any change.
Thank you very much for replaying
Per
Its worth remembering that the data you want to lift is relatively small compared to the overall network load - can I ask you what speed the bus is running at , and what makes you say that you think you are loading the network up ? ( though you are definitely making it work !) I would have though that the processor would get bogged down first , it is not a particularly powerful beast .
I'm glad to see that you have separated the I/O and HMI's .
Could you post a screen shot of the profibus diagnostics window ?
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
198
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
94
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
115
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
328
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
327
