Profibus
ABDELAAL
Dec 2007
ALEX.
32
HI EVERYBODY,
I've a plc siemens S7-300 and I want to interface a profibus based flow meter do any one have a solution for this ?
In what way do you mean "do any one have a solution for this"?
You will need the GSD file for the flow meter; ask the supplier for it.
I mean that i need a manual for fb for cofiguration of the profi. i think first time it wasn't clear
You will need the manual for the flow meter and also the gsd file.
This will tell you what data areas can be used and what bytes or words within the data area are for what.
With this information you can write your code for the PLC
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
198
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
93
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
114
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
328
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
326
